Dies At Trafic Lights
Evening all,
My truck has taken to dieing at traffic lights unless the brake is pushed all the way down and even then sometimes. I have noticed that the idle speed on the tach has dropped about a 1/2 to 1/2 of where it used to be.
Thoughts on where to look and an easy fix? It was doing this before I changed out the plugs, wires and cap and rotor. Seemed to have gotten worse the last couple of months. I am putting less than 200 miles on it a month, so it is sitting a lot. Water in the tank? Change the fuel filer if it has one? A fuel treatment? It has never done it in park, only in drive with foot on the brake. If it had a carburator I would just try adjusting that to a richer mix, I know nothing about fuel injection systems.
Clean the throttle body, pay special attention to the IAC well. It likes to crud up, and cause these issues. Leave the battery disconnected while you deal with the TB. When it's all back together, turn the key to "On", (not start) count to ten, then start it up. (don't touch anything) Let it idle for a bit, and the PCM *should* relearn idle.
Trending Topics
