Headlights Don't Work
#21
If it has the Aero, you could upgrade to a HID projector set; there's enough room in there for the smaller ones.
If 4x6 already, well, you've got the same choices I have.
RwP
#22
I'll add that there's probably better choice to get a 9004/9007 LED that would possibly work better. But!
YOU HAVE TO GET THE FOG OFF THE LENSES!!
I can NOT emphasize that enough!
I'd also try some NightBreakers or some other high end halogen first; plus, add the relay.
Add the relay no matter WHAT you do; the wiring's too small, and it runs too far, for the lights to work effectively.
RwP
RwP
#23
RwP
RwP
#24
For people interested in the 4x6 replacement headlights I did a little checking online. The part number for the 'buckets' is 3868926 / 3868927 and if you look those up it said those are applicable for 1987-96 Dakota, so in support of my original claim that the headlight parts never changed for 4x6 from 87-96 even though the rad support did etc.
For aero people, I 'defogged' my aero composite headlights with 1200 grit sandpaper and then polishing compound on a buffing wheel. While it makes the situation much better you're still pushing light through a plastic lens which is IMO not entirely clear.
This is before / after comparison, on the right is sanded polished headlight on the left nothing. I never did the one on the left, I found a brand new TYC headlight at the JY for $5 so I got that instead. And I've seen Dakota (and other plastics) headlights that are worse than mine were, but like Ralph said when you get older the lighting is even more important, so that's the main reason I'm switching to the 4x6 setup.
Honestly, I wish there was enough room in there to fit the 200mm rectangular H4 headlights or even the 7" round H4 type, but that's just way too much custom work for me at this point.
Steve
Steve
Last edited by glenlloyd; 01-03-2019 at 04:00 PM. Reason: wrong photo first time around
#25
For the 9007 headlights, here's a representative unit:
That's NOT the only one out there, BTW! That's just representative.
If you go 9003, you'll need one more like
If you keep the 4666, enjoy hand making one.
(TBH - I made a 4666 one, then adapted to 9003/H4 bulbs, so I can keep as much wiring as possible native.)
RwP
RwP
#26
#27
I'm just pleasantly surprised they didn't do a 3-on-the-tree manual transmission.
RwP
#29
OK, my headlights work again. Replaced the switch with a Mopar replacement. Not too bad of a job. Plug was a little hard to get off the old switch. The cowling under the steering wheel a bit of a PITA to put back on (screw alignment). Other than that not a big deal. The new switch had a broken tab on it (where the plug snaps in). So only one plug tab is holding it on but doesn't seem to be any problem. New switch works like a champ. Back in the saddle again. Switch cost me $54 off of Amazon.
Remove 8-10 screws from dash face. Remove cowling underneath steering column. Remove five screws around headlight switch. Pull **** out (hold down release button on switch). Unplug (two tabs need to be released). Reverse process. There's a video on You Tube too for a 93 Dakota.
Thanks for the input fellas. Ed
#30
At least fleet purchases were 4x6 standard; I don't know, as I said, it may be 95% to 99% came Aero, but it was an "option". Like carpet instead of rubber floor covering; AM/FM radio (yes, you could order a 1988 with an AM mono, or even no, radio); etc.
RwP
RwP
This is the donor for the first front end I found, bought the whole thing off that one, this truck is a 1993 and no indication that the front end was ever modified.
Found this one in NE Iowa junk yard in Rowley over Christmas, it's a 1992, bought the grille and headlamp trims from this one too, too nice to leave there!
This one was also non-aero front end, but I never checked the year. It was 4 cyl 5 speed truck
Another 4 cyl MT non-aero front end, could not check year on it but it was base and it could have been a fleet truck?
Steve
