fuel delivery issue
Alright long story short. i had a good write up but my browser crashed and lost it. the trucks fixed . the problem was the wiring harness mounts rusted and failed dropping it under the fender . it then wrapped its self up around the front suspension . i must of hit a pot hole in the ally and it clipped 3 of the wires clean and chewed up one. i made repairs and it fired right up and runs like a brand new truck. i never thought about the wires being clipped like this because every where i was looking the wires looked clean and with out issue. i spotted a dangling wire while under the truck and took the front tire off and then found this mess. Thanks for putting up with some of my dumb questions. electrical is kind of a weak topic for me. Thanks for the help trouble shooting.
honestly. i dont mean to be a pest. but is there anyway some one can explain what im looking for for the splice here? i tired to read the manual i downloaded but it is literally Greek to me. i dont understand why some manuals have to be so complicated. all i can see is numbers and crude sketches of what the wiring looks like. if they would just be so kind as to say "this red wire from here goes to here. or this pink wire goes here check here" it would makes a lot more sense . perhaps im blind though. *sigh*
Word of advice.... Pull your entire harness out of the truck and rebuild it. Go over every single solder"splice" and connection. Use lots of electronic cleaner, resplice all of the factory splices with fresh solder and make sure u use 3:1 self sealing heat shrink tubing to make sure your connections stay completely out of the weather. Use some fine grit sandpaper and a tooth pick to clean the contact surfaces on every connector. Re wrap the harness in wire harness tape. Please don't use electrical tape whatever you do, I found out the hard way that it melts and turns into a gooey mess. Click on my name, I did a small write up on my harness
