Old 08-05-2015, 07:54 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Exterior
Print Wikipost
windshield wiper problem
Old 07-05-2018, 02:56 PM
Kyle Samuel's Avatar
Kyle Samuel
Kyle Samuel is offline
Default 92 Dakota Wipers not working
Driver side wiper stopped working so I took of the wiper arm to find that the teeth on the wiper pivot had been stripped. Anyone know where I can get a new one? I tried superglue and Jb quick weld and it worked for a little while but then failed. Jb weld won't hold it together any more. My inspection is up to and i can't go get her inspected with out this wipers working.
  #22
Old 07-05-2018, 04:37 PM
RalphP's Avatar
RalphP
RalphP is offline
Wrecking yard.
Suggestion: Get the WHOLE transmission, and replace all the bushings while you're swapping out, also be sure to use some lithium grease in the bushings when you put it back together.
RwP
  #23
Old 07-06-2018, 06:11 PM
Kyle Samuel
does the transmission com with the new gear pivot things?
  #24
Old 07-06-2018, 07:07 PM
tbugden's Avatar
tbugden
tbugden is offline
You are probably best looking at a junkyard. I imagine you could weld the shaft to the wiper arm as a last resort. Could also potentially drill a hole through and use a roll pin... But I bet that shaft is very very hard... Metal. Ha.
  #25
Old 07-06-2018, 07:22 PM
RalphP's Avatar
RalphP
RalphP is offline
From the boneyard? Probably not.
And they're called 'bushings'.
I have the part numbers here somewhere for the Dorman parts; it's been reported that the Mopar parts from the dealership last longer (I can't say, my Dormans are about 5 years old now ... )
I've attached a pic that's been resized showing the part numbers. The orange Dorman box is a 10 count; the hangers are ones you'd find at the HELP! counter.
(That arm below is one of the transmission arms; you can see the date and time I took it; and yah, I'm still rocking that set.)
RwP
  #26
Old 07-07-2018, 10:38 AM
Kyle Samuel
its not the bushings. its the wiper pivot that connect the wiper arm to the transmission.
  #27
Old 07-07-2018, 11:38 AM
RalphP's Avatar
RalphP
RalphP is offline
Yes, I got that.
You have to get it from the boneyard ANYWAY.
While you're there, I'd get the ENTIRE transmission, and rebuild it.
That's what I said.
RwP
  #28
Old 07-07-2018, 01:01 PM
tbugden's Avatar
tbugden
tbugden is offline
****, I just remembered I have a whole parts truck sitting in my yard. Kyle if you can't find or don't have a junkyard near you let me know, I can send you the whole assembly for $2 (just to pay for gas to go to UPS) + shipping. So I'd guestimate somewhere around $15-$20 total. lemme know. I'd throw in the wipe arms if yours are damaged too. You'd still want to replace the bushings of course.
  #29
Old 07-07-2018, 01:26 PM
RalphP's Avatar
RalphP
RalphP is offline
If Kyle doesn't want the wiper arms, I'll take them; I want a spare set of good ones to paint flat black and swap onto the truck, instead of the rust red ones I have now.
RwP
  #30
Old 07-07-2018, 01:47 PM
tbugden's Avatar
tbugden
tbugden is offline
No you can't have them.
Quick Reply: windshield wiper problem
