Last edit by: IB Advertising
Browse all: Exterior
- Dodge Ram 2nd Gen Why are Wipers Not Working
Guide to diagnose trouble and recommended solutions.
windshield wiper problem
#31
#33
I'm sorry I wasn't clear, I was talking to tbugden about the wiper arms.
RwP
#34
#36
just had to do that very thing for my 92 yesterday. pass side wiper pivot had the spline break from the shaft, replaced all the bushings and tried to weld the 2 pieces together when I had my original wiper transmission out..... worked for about a month, couldn't lay the weld on or burn it in very hot as the pivot that it spins in is plastic, in my case, since all bushings are new, I think that I will just replace the pass side wiper pivot and pop the driver side pivot off of the rest of the junkyard linkage, tag it, and toss it in my bottom toolbox drawer for a spare.... don't actually need the linkage in between.
and on the bushings.... check Dodge. they ARE still available. Not cheap but you do get what you pay for..... I have tried Dorman ones -- I remember when Dorman was largely Domestically made, now almost none of their stuff is... They are a thinner softer plastic, yes easier to pop in but I hope you like repeating the job in a year at most-- because you will. I like doing a given job on the same vehicle only ONE time. (besides consumables like tuneup parts, brakes, fluids and filters) using Dorman will give you a sense of "job security"!!!! I have bought these very bushings twice from my local Dodge garage twice this year-- had them on hand both times. and the extra effort to get them to pop in is worth it, have used them on other vehicles (I have only ever owned Dodges, never anything else to date) and on any given vehicle I have never had to do one twice. and I have been known to drive them into the ground, never afraid to take off at any time for any place.
#37
name of the 2 splines shafts
The arms don't want to come off the splined shafts. I know to pull the clip and wiggle it, but it's being just a big pain in the butt. My question is I can't seem to find the 2 splined shafts that the wiper arms attach to anywhere online. I've tried rock auto,Lmc Truck,dorman OE solutions. I have to change them. The shafts are just spinning inside the arm. Any help would be greatly appreciated.
#38
Boneyard is the only current source. Unless you get really lucky at an Obsolete Parts vendor (check out Partsvoice and Rearcounter ... both linked in the FAQ2) Just as a note, from the 1986-1987 parts list, they list as:
4249 608-9 1 PIVOT, Wiper Pivot
Which means a 4249608 and a 4249609
What a few have done has been to drill a hole in the wiper arm, tap it, and put a lock screw in. Might have to drill into the driveshaft there to make sure it bites good.
Also, check the arms; I've seen THOSE desplined with age, and the Dormans I tried didn't have very well defined splines either.
Arms from similar vintage Jeeps fit and work, albeit they're not "right".
RwP
RwP
#40
