Fuel Gauge Problem
#31
The gas gauge quit months ago (empty reading). After being T-boned I had the body shop replace the fuel gauge sensor while the bed was pulled back. The gas tank was about 3/4 full at that time. They replaced the sensor with an after market unit which the first one did not register gas level. The second unit seemed to work OK. When I got the truck back the gauge indicated about 3/4 full. I filled the gas tank I got the usual over fill indication. However, the gas gauge now does not drop below about 3/4 full. I put over 14 gal of gas in the tank after the trip indicator read 185 mile. I read several of the gas tank threads and am sort of caught in the middle. Is there a reset or calibration that meeds to be done after a fuel sensor replacement? I hate to have to take it to the dealer and spend big bucks. Maybe the float is stuck?? I would pull the pump sensor, but, not sure what I would be getting into?
Lou K
Lou K
#32
#34
Two suggestions if the diagnosis Raplh suggests does not work https://dodgeforum.com/forum/1st-gen...gas-gauge.html
And a TSB also haveing to do with the sending unit. IDk what year yours is but it applies to 91-94 dak http://dodgeram.info/tsb/1994/08-33-94.htm
Also this https://dodgeforum.com/forum/1st-gen...-friendly.html
You can lift the bed instead of dropping the tank. It's 8 bolts, disconnect the fill tube on one end of the rubber connector, unplugging a couple wires near the bumper, and the spare tire escutcheon.
#35
#37
Cluster's easy. Using the voltmeter, a) make sure that the gas gauge is getting power; b) check the resistance to ground of the sensor line. If b) is open, it's the wiring between the pump and the gauge; I personally would bet on that before I bet on the gauge. But that's what the testing's for.
RwP
RwP
#38
RwP
RwP
#39
Rear harness
Yeah what Ralph said....the cluster can't hardly go bad, but good spot to check your sender. There are two signals that come directly from the sending unit to the cluster. No pcm involved. It does go through the rear harness connector by the driver side fender and then the bulkhead connector into the cab. One signal is the ground signal to the empty lamp. One side of that lamp always has 12vdc from the cluster bus. The other side of lamp gets a ground from the sending unit when the contact on the bottom of the wiper is made. If the lamp is always on either your float i's stuck down or the wire is shorted to ground. As for the gauge the wiper in the fuel sending unit is a simple voltage divider using varying resistance. You should see a change in voltage at the gauge between 0 and 12vdc depending on the float position. You can measure the voltage or resistance with your meter to check.
#40
No, the rear harness connector (there's two) are the grey and black connectors near the fenderwell inside the engine bay on the drivers side. They snake down the fender then follow the frame back. They cover the harness for the rear lights, abs, and fuel pump and sender. The trailer harness you speak of is usually just spliced onto the rear lights and shouldn't affect the fuel sending unit.
