Symptoms of bad PCM?
Old 03-08-2015, 01:48 AM
Shannen's Avatar
Shannen
Shannen is offline
Default 1996 dakota 3.9 v6
I have 1996 dodge Dakota 3.9 v6 that is stalling when u take your foot off the gas. It hesitates while driving sometimes it it feels like it died when driving but I hit the gas and for sevral pumps there is nothing then it chugs comes back to life and back fires. This seems to be worse in the evening or when its cold outside.
Old 03-08-2015, 01:50 AM
Shannen's Avatar
Shannen
Shannen is offline
any help would be greatly appreciated, replaced cap/rotor, plugs and wires, batt. connectors, and cleanend the throttle vaulves
Old 03-08-2015, 05:52 AM
RalphP's Avatar
RalphP
RalphP is offline
How about the crank and cam position sensors?
What codes are it throwing?
Since it's 1996, it's OBDII - have you connected a competent OBDII reader and seen what the data stream says is going on?
RwP
Old 03-08-2015, 02:23 PM
Robertwav1's Avatar
Robertwav1
Robertwav1 is offline
I just replaced the intake gasket on mine, leaking internally. I took off the throttle body and looked inside with a light and seen filmy residue on the inside. Probably a small leak but enough to make it die and come back to life again. I was getting a misfire on cyl 1 once in a while but that's about it for codes. Easy enough to check and it don't cost anything to have a peek inside. I had no external leaks on the intake which would give you a vacuum problem. Only air and fuel in the intake is allowed....a little moisture really messes you up. Listen to your exhaust at an idle as well. Mine was sounding all jarbbled, now it's just a steady pule like it's suppose to be.
Old 03-08-2015, 03:05 PM
00DakDan's Avatar
00DakDan
00DakDan is offline
Section Moderator
Dodge Forum Moderator
Thread moved to the 1st gen forum.
Quick Reply: Symptoms of bad PCM?
