My new TOYS!! 10,000Lbs Winch
Old Oct 21, 2009 | 01:03 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Wink My new TOYS!! 10,000Lbs Winch
Okay so today I installed my new skid plate. Next I went to 4wheel parts and went all out.
I bought a NEW Optima yellow top battery. I had my last one die about 6 months ago. So i bought another Optima craigslist special for $20. I knew it wouldn't last to long. So around 6 months it died.
Next I bought a winch. 8,000LB. http://www.4wheelparts.com/Winches-W..._pn=S%2fB97281
They were out of stock so it should be here in a day or 2.
The last thing was from Checkers or I should say O'Reillys. A Bulldog Remote starter/ Alarm with key-less entry. My current one is dying. First the remote starter was not acting right. Next the door unlock wouldn't work. So it was time for another.
Edit: Here are pics of it installed.
Old Oct 21, 2009 | 01:31 AM
95_318SLT's Avatar
95_318SLT
Dang Crazy!!! Were those winches buy one get one free :P I want one!!
That'll be sweet once you get all that installed.
Old Oct 21, 2009 | 01:39 AM
Crazy4x4RT's Avatar
Crazy4x4RT
I wish it was. But it is a great price!
I will go to Harbor freight and buy a hitch mount for the winch. That is why I made the front hitch by the way. http://www.harborfreight.com/cpi/cta...emnumber=66409
I bought 15ft of OO wire to power up the winch in the rear. I also already had 3 gauge wire run to the back for the small hidden winch I had.
Old Oct 21, 2009 | 03:11 AM
skyshark186's Avatar
skyshark186
Gusset the winch mount. Take it from personal experience. Its possible to rip it in half.
Sweet. Getting cooler all the time. Next youll have to rip off my plans I ripped off from someone else to build an on board air unit for under 150 bucks.
Old Oct 21, 2009 | 10:28 AM
Crazy4x4RT's Avatar
Crazy4x4RT
So you riped one in half. Dang that must of been one bad night!
$150 for on board air, hum not bad. Lets do it!
Old Oct 21, 2009 | 12:14 PM
skyshark186
Yup it was. The reciever stayed where it was and the winch and half the mount didnt. It wasnt my setup, but I was the anchor for the event. I would gusset the mount from below off the reciever tube if they havent already. It was at a slight angle and just tore it in half.
Ill post up the process as soon as I get a chance to get to a pick and pull for the york compressor I need.
Old Oct 21, 2009 | 04:14 PM
LO 619's Avatar
LO 619
dude that is gunna look SAH-WEET. I guess just figure how you can re-encforce the mount some. If you can cut and weld you can probably think of something.
Old Oct 21, 2009 | 05:43 PM
Bump's Avatar
Bump
I thought you had a portable winch for the front already. You have the hidden one in the rear too, no?
Old Oct 21, 2009 | 09:20 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Ya I have a portable one and the hidden one. But they are only rated 2,000lbs 3,000lbs. Not enough streanth to pull out me out if stuck. Mostly others will be stuck, not me.
Old Oct 21, 2009 | 09:36 PM
ZackN920's Avatar
ZackN920
Thats kick *** man,....
i should probably look for a newer battery because mines from 2001 according to the label
