Stripped out caliper bolt hole...help!
Old 08-30-2012, 09:17 PM
eli346's Avatar
eli346
eli346 is offline
Default Stripped out caliper bolt hole...help!
I have a 94 4x4 dakota that i bought about a month ago and the drivers side brakes were making weird noises so i pulled it apart and the caliper was only held on with one bolt! I bought a new bolt set and then found that the top mounting hole is stripped out so i did some searching on this forum and ended up buying the oversize caliper bolt from Napa after seeing a few people on here used it with good results but the bolt wont even start to thread in. If you fixed yours this way did it thread right in for you?
Any other ways to fix it?
Old 08-30-2012, 10:32 PM
91_dakota's Avatar
91_dakota
91_dakota is offline
mine stripped too and i just used a heli coil and the original bolt
Old 08-30-2012, 11:58 PM
Hahns5.2's Avatar
Hahns5.2
Hahns5.2 is offline
Napa carries a Heli-coil kit that I used.
Old 08-31-2012, 05:18 AM
JR318's Avatar
JR318
JR318 is offline
Im dealing with the same issue on a little chevy cavalier that a buddy of mine just bought. His front passenger side only has one bolt and the helicoil for his is $87. Its a m11x1.5 so im going to drill and tap it to the closes standard thread.
Old 08-31-2012, 05:45 AM
bwdakrt's Avatar
bwdakrt
bwdakrt is offline
The oversized bolt will cut new threads in the hole as it goes in so no it won't just screw in at the beginning.
Old 08-31-2012, 07:54 AM
One to Remember's Avatar
One to Remember
One to Remember is offline
u might wanna try a nut and bolt if possible or go to a store and get u a bolt with a close to flat head
Old 08-31-2012, 08:39 AM
bwdakrt's Avatar
bwdakrt
bwdakrt is offline
NO!!! The caliper has to be able to slide in and out on the caliper bolt. DO NOT bolt it stationary!!!
Old 08-31-2012, 10:44 AM
eli346's Avatar
eli346
eli346 is offline
That's what I've been trying to get it to do but it wont even catch and start cutting new threads it just keeps spinning on the end like the bolt is to big for the hole
Old 08-31-2012, 11:08 AM
bwdakrt's Avatar
bwdakrt
bwdakrt is offline
The threads on the standard caliper is M9-1.25. With a stripped thread type deal the over sized bolt is designed to use the stripped size of the hole and cut new threads in the spindle. Try applying some pressure inward while turning the bolt and see if that helps. Also it's a lot easier to do with the caliper removed.
Old 08-31-2012, 11:57 AM
eli346's Avatar
eli346
eli346 is offline
That's what I've been trying it just doesn't want to go so I'm wondering if maybe the threads or something are messed up on the end of the bolt even though they look fine. Ive wondered a few times if it's even the right bolt because it seems huge for the hole and the bolt head sticks out an inch or more farther than in needs to in the back and the spacer thing doesn't even fit through the rubber piece so it doesn't seem right
Quick Reply: Stripped out caliper bolt hole...help!
