93 dodge dakota brake fail help!!
Old 03-08-2014, 05:46 AM
countryroads's Avatar
countryroads
countryroads is offline
Default 93 dodge dakota brake fail help!!
Just got myself this 93 dakota 4x4, had it sit for a week. Suddenly brakes barely workes when i insured iit today. I had to push all the way and the abs and e brake would light up but fade away. The ebrake i know sucks already
Brakes worked but barely checked fluid filled it up didnt drain and i test it next thing i know legit NO brakes.... wtf happenes abs and ebrake lighta stuck on and like im gunna check foe leaks and pads tomorrow... juat bought it had a recent wngine rebuild
Any help is good help... 4.9L v6
Old 03-08-2014, 09:01 AM
jkeaton is offline
Dodge Forum Administrator
Welcome to DF. You posted in the wrong section. Moving for you.
Old 03-08-2014, 12:08 PM
countryroads
Just joined last night still learning site
Gunna go check it out hoping they have just worn pads or leaking fluid... never had brake fail %100 on me before
Old 03-09-2014, 12:41 AM
shadowthedakota's Avatar
shadowthedakota
shadowthedakota is offline
Did they fail as you were driving? If they failed as soon as you pressed the pedal before leaving on your trip then it's more likely a broken line or a leaky rear wheel cylinder. Take a look under the truck for any signs of brake fluid running down from somewhere under the truck.
Quick Reply: 93 dodge dakota brake fail help!!
