Dakota Rear leaf spring shakle...
Hi Everyone,
I could really use some help finding these. I need a Left and Right rear leaf spring shakle mounts for my 1995 Dodge Dakota 4x4 3.9L V6. These mounts would be the ones located closest to the rear bumper. My current ones have rusted out. My mechanic contacted Carquest and they do not have any nor could they find anyone who had them. I'm hoping to be able to find a website selling them that also has pictures so I know I'll be getting the exact parts I need.
If anyone can help me with this, that would be great! Thanks!
-Moparman1995
-Moparman1995
If you refer to the picture at http://www.factorychryslerparts.com/...ssembly=591561 - you're looking for the part called out at #9 for the 1600# springs, or at #13 for the 1800# springs, right?
The dealer should have them, but you can also take the part #s off that page and Google for them if you want them somewhere else.
RwP
RwP
These are what you're looking for. http://www.rockauto.com/catalog/rafr...&parttype=7484
edit: Picture and better price here... http://www.stengelbros.net/product.a...q8YaAoWJ8P8HAQ
Finally I was able to log on. Sorry I didn't get to reply sooner guys, had issues with my account on here for the last few days.
Some aspects of my post were a little out of whack. My mechanic had written down "shakles" when it's shackles. And also "mounts" when they are referred to as "hangers" as in rear leaf spring shackle hangers. I found them online finally after searching for days, even looked into what you two had told me but those were dead-ends. I finally found the exact replacements: http://www.autoandtrucksprings.com/p...r-1886-81.html. I plan on buying the entire kit though with 2 hangers, 2 shackles and all the bolts etc. needed. I might as well since the driver's side hanger is not far behind breaking and new shackles will work better than the 20 year old ones that are on there.
Thanks guys for the help and a special thanks to Crazy4x4 for the account help.
(One reason I linked the pic - if you were asking about something besides what I was thinking you were, at least you could go "Oh, that's part # 94/QZ4 on the call out!" *grins* )
RwP
Trending Topics
@Crazy4x4RT Thanks, me too!
@moe7404 I assume you're being sarcastic? Why would I want it to come apart in the snow? Unless you're trying to say that it would need replacing by then and the anti-seize would help it be taken apart even in the coldest temperatures.
@RalphP I realize now that it's the same part but it looks a lot different in the schematic you pointed me to which is what threw me off at first. In schematic it's a triangle shaped hanger with 3 holes, actual one for my truck is 6 holes and is more of a circular shape.
@tbugden Yeah, sorry, I was only using the terminology that my mechanic wrote on the piece of paper for me. Actually the rear of the frame has no holes as of yet, where there is some holes starting to rust is on the bottom of the boxed-in section on the front of the frame behind the front wheels. It's probably from a combination of road salt/sand mix hitting there from the tires and also being on various lifts in the past (pressure being applied and released dozens of times there over the years). Even some stress cracks in those spots. BUT in the C-frame section isn't too bad, I usually try to clean out the bottom of the C section in the spring and whenever possible so salt etc. doesn't sit there and rust more.
For an update, I ordered the entire kit earlier tonight, $239 (little pricy) but should be well worth it!
It's so weird how the same trucks rust in completely different places. My frame rails rotted out terribly in the rear, though the hangers were still more or less sound. Not good, mind you...but considering the condition of the rest of the frame, not that bad. The front half was pretty much fine, except for the upper control arm mounts...those were real bad.
Good that you're trying to keep it clean. It's almost 20 now, maybe you can get another decade out of it!
