No brake light on one side
Hey, my gf has a 96 dodge pickup, not sure of model but I doubt it matters much for this issue. She has a brake light out on the passenger side. Tail light and turn signal work. It uses a dual filament. I read the turn signal filament is the same as the brake light. So the bulb is fine. If that filament is working then obviously the wire is getting juice. What else could it be? A fuse or switch?
thanks
thanks
thanks
thanks
That's the first place that the right and left change for brake lights; I'd be looking at that first.
Especially if the center high mount stop light (CHMSL) is working, as well as the driver's side brake light, and with both sides working for turn signals.
Edit: Just checked RockAuto (my go-to source); they have them from $75 down, and you'll have to know if she has intermittent ("pulse") wipers or not. You can find 5% discount coupons all over the place; for a MFS, that 5% will just about cover shipping/handling.
RwP
Last edited by RalphP; 05-19-2017 at 09:49 AM. Reason: Price of switch at RockAuto on 19 May 2017.
