Help please
Help please
Hello I have a 1991 v6 dakota I'm going to be doing the head gaskets I have everything so far, but I can't seem to find head bolts any where online only the ones for a 4cyl Dakota idk if those will work or not can any one help me out please I dont really want to reuse the same bolts.
Here's an ARP set: https://www.summitracing.com/parts/a.../make/chrysler
RwP
Look for LA family 273/318/340/355/360 V8 bolts; you'll end up with spares, but those'll work fine.
RwP
RwP
Except for having extra bolts for the other two cylinders, yes.
The 3.9 in your 1991 is a LA V6; those are for an LA V8.
So extra bolts left over; no problem.
A lot of other items for a LA V8 also fit; torque converter bolts, flexplate bolts, flywheel bolts, exhaust manifold studs and bolts, valve cover screws, water pumps, studs etc there.
RwP
RwP
RwP
RwP
Some doesn't directly, natch; the crank and cam are different due to being 2 cylinders shy on the 3.9 *grins*
Pistons and rings swap; connecting rods are a bit thinner at the crank end on the 3.9 due to the split crank.
But overall, think of a 318/5.2 LA motor, less two cylinders.
RwP
RwP
RwP
RwP
Trending Topics
Also, the reviews mention that there may be two or three different lengths; see if ARP or whoever has a 3-length set for the LA small block V8.
For 3 bolt lengths, here's the Mopar Performance package: https://www.summitracing.com/parts/dcc-4120471 Again, if you know the thread and the length, you may be able to replace with other sources also. But look for the V8 sets; you'll just end up with some extras left over due to the "missing" two cylinders.
Edit 3: Here's a listing with the lengths of bolts and the sizes: https://www.yearone.com/Product/1966...-e-body/fd1201
BTW - That Haynes book? Doesn't even make good toilet paper; what you want is the genuine Factory Service Manual.
The Haynes book reads like a "Joy of Beef!" book written by a vegan, or a "Joy of Sex!" book written by a virgin; i.e., all too often it has NO idea what's going on. And if you ever get to electrical in it ...
RwP
Last edited by RalphP; 08-15-2017 at 08:39 PM. Reason: Note about comments; Added another set; Last time I SWEAR!
I'll add this as a quick reply - ARP lists a 3-length set; http://arp-bolts.com/kits/ARPkit-det...p?RecordID=422 .
Shop around for that part number; it's probably available for less. It's ALREADY less than the Mopar Performance everywhere I see it *grins*
RwP
RwP
