cam timing
cam timing
Yes,to a few motors.It's just a bit more TLC that the cam& crank triggers get closer function with each other,Then the PCM -computer can really wake up the motor.109 degree is the number.U TUBE and instruction with the wheel guide you.it's strait forward,easy too follow.As a rule with all motors I build,degree of the cam is important enough to do beside lining up the dots.Just a thought..................................
Gotta be careful with that though. The tensioner is designed for use with the morse style chain, it has lots of surface area for the tensioner to ride on. I went with a double roller chain, and I suspect that would eat up the shoe on the tensioner is pretty short order, so, I didn't install one.
RwP
