Upper Control Arms
Upper Control Arms
My left upper control arm was wrecked and I got another donor one but the bolt hole has rusted out and the control arm bolt slides around. Not safe! So I am looking for an upper control arm if anyone could point me in the right direction I'd be happy. I live in British Colombia Canada and could travel to Washington, Oregon and Idaho to pick up parts.
On Ebay, there are 3 listings.
1. used for $65.95 4wd
2. Used for $40.00 2wd, but it may be the same as 4wd.
3. New for $535.00!!
On a side note, if your bushings are wore out, and most are on this old of a truck, You can use a poly bushing set from a 97 and up. But you do have to shorten one of the lower bushings. Search this site for more info. if interested. Its been documented several times.
