1996 dakota will not start when warm
I have a 1996 dakota 3.9 v6. Manual tranny.
will start cold. Will run perfect til shut off at operating temp. Will not start back. was parked for 6 months. we have already replaced the: plugs wires dist cap rotor cam position sensor crank position sensor fuel pump idle air control valve what are we missing? thanks in advance. |
PCM is about all that's left.
Find out if you are missing spark or fuel.
Originally Posted by magnethead
(Post 3375585)
Yes that's what you need to see, if it is firing the injectors or not. Check for spark by grounding a connected spark plug.
Moved to the 1st Gen forum.
As mentioned, check for spark. Borrow or buy a set of NOID lights (most of the bigger auto parts chains will "loan" them to you - you buy them, but get your money back when you return them, on their version of the Loan-A-Tool program, for the units ON said LAT program) and verify you're getting injector fire.
Before I REPLACED the PCM, I'd disconnect the negative battery cable, then five or six times take the connector(s) off and put them back on, then reconnect the negative battery cable and see if that helped any. It may be as simple as corrosion that gets worse when it gets warm. RwP |
Originally Posted by RalphP
(Post 3375678)
Before I REPLACED the PCM, I'd disconnect the negative battery cable, then five or six times take the connector(s) off and put them back on, then reconnect the negative battery cable and see if that helped any. It may be as simple as corrosion that gets worse when it gets warm. RwP will give it a try. Thanks. |
(Post 3375678)
If they're not getting power, you trace the wiring back to where they don't get power. In a Dodge, that's upstream to the Auto Shutdown Relay; pull it, bypass it, and see if you have power. If so, you then see if it's the relay failed or the signal from the PCM; easiest is to swap the relay. (On my 1988 it's a Bosch style relay; I have a few I bought at $1 each, so easy to swap.)
RwP |
