Stalling Issue Stopping
New to the group. Second 1 Gen I've owned. Not sure what area this problem needs to be posted under.
I recently got a 95 4x4 5.2 Auto. with 176000 miles on it.
I've replaced.
Front Rotor and breaks.
TPS
IAC
Oil Changes
Bad lead at dipstick tube. sealed. new o-ring.
I seem to have a problem during what seems to be the first 5 five miles of driving. When slowing to a stop the vehicle will stall. It will start right back up and run okay until the next stop, Sometimes when stopping it will lurch a bit forward.
The truck idles fine in park and neutral. Cold and Warmed up.
After about 3-5 miles of driving the stalling goes away and the truck runs pretty well.
Error code of 37 is shown when checking. No check engine lite is on.
Transmission fluid in in really poor shape and I do not know when if ever any fluid was changed in it.
Any ideas or suggestions?
I've replaced.
TPS
IAC
Oil Changes
Magnum Engine?
Take a look down the throttle body, see if oil is pooling in the bottom of the manifold.
Might just take the throttle body right off, and clean it good. Special attention to the IAC well.... (careful cleaning the IAC itself, don't press on it too hard.....)
Code 37 is for TCC, when it stalls at a stop, does it feel like trying to stop a manual trans truck, without pushing in the clutch?
Also might try disconnecting the O2 sensor, and see if the problem goes away.
Magnum Engine?
Don't see any pooling. IAC was replaced and I cleaned the area.
Code 37.. Exactly just like stalling a manual transmission.
Thanks will do.
I was able to disconnect it and drive for about 3 miles total. Still had the stall issue.
II have not plugged it back it as the connector was filled with fluid, Can that create a voltage connection? This is a very hard spot to get to to clean so what can I clean it with that will safely clean the plug of the transmission fluid on both ends?
Trending Topics
Good point. I figure I'll order the solenoids for it. Do you know if the transducer solenoid has an oval plug or Square Square one. I can't seem to find good information on it.
