Front turn signal bulb replacement.
RE: Front turn signal bulb replacement.
Maybe i'm out of line here but if you are on the interweb and post a question, you are bound to get all kinds of answers ranging from step by step to a picture of midget rasslin. Sorry you got upset or offended at the replies you received. I have found quite a bit of good info on here just rooting around to see what was on here.
We cannot satisfy everyone's questions with the initial results of our answers. It all depends on how much accurate and detailed informationa userinitially post on this forum. I have been with this forum since 2003 and seen all kinds of users come and go and what they posted. From my view of users posting questions here asking for help, most of the time, the owners manual can answer up to 80 percent of their basic questions. The remaining 20 percent are recommended to have a chilton and/or haynes manual for users that needs very specific details on a repair in question.
Otherwise, in most cases, other issues can be easily explained by our users without consulting with a manual.
I am a very passive moderator and very tolerant of alot of things that get posted. Sometimes new users may not know how to post theirquestions accurately, or they may be those users that want a straight answer nomatter how puzzling their questions are. If Hydra saw this post, he would have a field day and problaby immediatelyput this user out to pasture after he responded back in a negative way.
Last night I went home and pulled the passenger side turn assy out to see how complex it was. Dang, after three minutes I had grabbed a T10 "screwdriver" and removed the tiny screw at the bottom of the gap between headlight and side light and slid the turn/side marker assy out. Another ten minutes it was back together and the right signal was working properly. I had to find a bulb in my electrical box hence the ten minutes. Sorry to see what could be a good member get pissy and more than likely never come back.
One symptom of a rapid turn signal flash may be due to a burnt out bulb, in my case it was on the driver side front signal - there are actually two in my case.
To replace it is fairly simple with the right tool. You will need a torx/star screwdriver (T-10) to remove the single screw that holds it in at the top ofthe signal lense - location is the bottom outside corner of thge headlight (was hoping to provide a picture, but appears my attachment size allowable was exceeded due to other posts). A picture would show this clearly.
The screwdriver used will need to be one that has a skinny shaft or you will risk cracking the lense. Once the screw is out, open up the hood because there is molding around the lense that has two holes that go into two studs around the signal lense that needs to be pulled out. Once they are removed you should be able to grab the lense on both sides and gently pull out evenly. There are two pressure clips on top of the lense that help hold it in. From there, it is pretty straight forward - turn the light buld socket counter clockwise and pull out of the lense, change the bulb and put back together in the opposite order.
