DodgeForum.com
DodgeForum.com (https://dodgeforum.com/forum/)
-   1st Gen Durango (https://dodgeforum.com/forum/1st-gen-durango-69/)
-   -   99 Durango...drivers window won't roll up (https://dodgeforum.com/forum/1st-gen-durango/198261-99-durango-drivers-window-wont-roll-up.html)
olcurt Apr 23, 2009 09:33 PM
I have electric windows and the window is down and won't go up. It was dark when my wife got home and I only got as far as taking the panel off and pulling the glass up and taping it so it stays up. I suspect the switch could be bad, but haven't confirmed that yet. I son't have a wiring diagram, bt was wondering if someone did, so I could jump across the two terminals for that switch and get the frame work to go up and be able to support the window for now.
Thanks!
schusterjo Apr 23, 2009 09:46 PM
regulator/motor on these is a common failure... $60-85-100 depending where you get it.
Simply cross the prongs on bottom side of switch to see if bad
olcurt Apr 23, 2009 10:05 PM
I put the switch back on and can hear it click but no action. Other windows are working ok.
IndyDurango Apr 23, 2009 10:36 PM
http://www.windowmotor.com/
or eBay for a stocker replacement.
© 2026 MH Sub I, LLC dba Internet Brands
