Exhaust Smell - Cat bad?
Hi all:
My 2000 4.7 V8 Durango (Automatic trans) has for sometime now stunk every time I started it up. What I mean by that is it has had a very strong exhaust smell upon start up. Bad enough that I have to shut down the air (Heat/AC) so it doesn't come wicking into the cabin.
More recently it seems like I get a gust of that smell not just at startup, but rather stop-n-go traffic (though sometimes it's hard to tell if it's you or the guy in front of you). The only other thing to mention is that I also get an occasional sharp smell of sulphur (rotten egg). Based on this latter fact, my unfortunate assumption is that my catalytic converter has gone (or is going) bad. Would anyone know whether the cat could cause both a exhaust blow back on startup as well as the rotten egg smell, or am I possibly looking at a more systemic exhaust system problem? Anyway for me to self diagnose?
PS: I've had it at Pepboys and the Dealer for unrelated repairs in the past 3 months and neither pointed out a problem with the exhaust. I figured that one of them would have brought it to my attention if there was an obvious problem, so I'm wondering if it's possible that I'm lucky and just need to pour some STP in the tank to clean out the injectors.
Well unless its an obvious issue nobody is going to say anything to u if there us an issue. I would not be taking my truck to a Pepboys unless i was getting some tires and or balance. Other then the smell have you done a walk around and tried to listen for a leak? a small exhaust leak usually sounds like a ticking sound in a way.
It is very hard to trust any shop today dealer or not, they all seem to be crooks anymore, there are very few honest shops left. Do you happen to know anybody who knows a honest place or person? try asking some friends at work if they know a good place to take it to. just thinking here you take it to the dealer your just going to get over charged and you take it to Pepboys ur just going to end up with a non quality job.
First off, just want to clarify that the PepBoys stop was an emergency, I was literally in the middle of the desert and the car was overheating (116F degrees outside that day). Basically all I paid for out of that stop was an oil change (though I don't think the oil was the overheating problem).
The dealer stop I mentioned was the fan clutch (also needed a recall performed)
As for other problems: Well yesterday my ABS light went on, and the Brake light too (that one usually lit when the parking brake is engage), also the speedometer suddenly doesn't kick in till 25MPH or so. I'm guessing this is unrelated, but since you asked.
Other info: 2 years ago the Durango started shifting really hard and I got a bad diagnosis that the tranny was bad from a local shop (that I will never return to). This was when the gas prices were close to $5/gal so I just parked the car and bought a used Jetta from my roommmate. A year later (almost a year ago now) I had a choice: Smog it or register as non-operable, I chose to smog it and the idea was to sell it with a note that the tranny was bad. Well I took it to a shop I used to use, they smogged and figured out the speed sensor on the tranny went bad. After that, no problems (except the exhaust smell and now the Abs/brake light issue).
Maybe just sitting for the year fouled everything up?
I sense sarcasm, but I don't understand if your saying a) Check my O2 sensor or b) that you don't think the cat is the problem
...or both or something else entirely.
Trending Topics
