Heater
Old 03-01-2010, 09:31 AM
Chronic01505's Avatar
Chronic01505
Chronic01505 is offline
Default Heater
Ok, Ill just cut right to the point lol...
So I replaced a heater core today but as I started to reassemple it I have noticed... something that looks like a dual vacuum line, wires are red and brown, I really can't find where this annoying plug plugs into ... Any ideas?
Old 03-01-2010, 04:25 PM
Chronic01505
bump!!! any ideas. I have looked around so hard and cannot find what it plugs into. Its part of the pigtail that is attached to the heater box.
Old 03-01-2010, 06:56 PM
SumAmerican's Avatar
SumAmerican
SumAmerican is offline
driver or passenger side?? it might plug into the back of the heater/ac select ****.. If i remember right the vacuum lines travel from the air tank on the passenger side to the selector **** in the center.. its a mess back there
Old 03-01-2010, 07:19 PM
SumAmerican
Found them.. follow your steering column down and you'll find a small round black tank thing around 3"-4" diameter. i'll try to post some pictures..
the second picture gives you a little bit of an idea where its at.. you can see the brake pedal and the steering column.
Old 03-02-2010, 08:50 AM
Chronic01505
OMG thanks soooo much I can see it in the bottom pic. It is definintely a mess back there. You really don't have much room to work around back there. That is very relieving to actually find it. I've pretty much avoided putting my car back together until I figured out where that was. Thanks ~!
Old 03-02-2010, 05:50 PM
SumAmerican
pm if your still struggling.. looks like we're local
Old 03-03-2010, 10:35 PM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
Hell, you could even go over and fix it for him! He only charges a few beers and a steak!
Old 03-04-2010, 09:53 PM
SumAmerican
I know right?!? I like beer.. I like steak... I also have a strange problem where I like to fix things that aren't really broken just so I can be working on this good old D.
Old 03-04-2010, 10:28 PM
shrpshtr325's Avatar
shrpshtr325
shrpshtr325 is offline
THE ULTI-MOD
thats my going rate too (assuming you are close by)
Old 03-04-2010, 11:45 PM
hydrashocker
Problem is you have to get the job finished before all the beer is gone or you'll be doing the job over again.......LOL
Quick Reply: Heater
