DodgeForum.com
DodgeForum.com (https://dodgeforum.com/forum/)
-   1st Gen Durango (https://dodgeforum.com/forum/1st-gen-durango-69/)
-   -   Got three remotes and can't get them programmed (https://dodgeforum.com/forum/1st-gen-durango/250429-got-three-remotes-and-cant-get-them-programmed.html)
Fox Fader2 Jun 23, 2010 11:41 PM
My initial FOB works fine. I wanted to add a second. I have 3 other remotes that have the same FCC ID# ( GQ43VT17T ) as the one I use. I use the instruction in the manual, get tone, but the remotes never program. Batteries all check good and place in properly. Could they all be bad or am I missing something? Two are the square type and one is the rounded OE.
hydrashocker Jun 24, 2010 01:15 AM
They need to be programed into the CTM by the dealer.
shrpshtr325 Jun 24, 2010 07:43 AM
yea it sounds to me like something weird is going on, i would see if the dealer could program them for you (no you should NOT need to have the dealer program them, but it sounds like the self-learn procedure isnt working for you)
© 2026 MH Sub I, LLC dba Internet Brands
