Starting problem...HELP???
Old 03-10-2011, 05:14 PM
SC Durango owner's Avatar
SC Durango owner
SC Durango owner is offline
Unhappy Starting problem...HELP???
I have a 2000 Dodge Durango, to begin with it wouldn't start only click when I'd turn the switch. I would have to keep turning the switch over several times and it would eventually start. I replaced the battery, alternator, relay switch and now the starter and it still won't start just click when you turn the switch.....someone please HELP?????
Old 03-10-2011, 05:31 PM
WhiteWidow00's Avatar
WhiteWidow00
WhiteWidow00 is offline
Check connections on the battery. Usually clicking is a bad connection or a bad starter but seeing as you replaced the starter, make sure its clean of corrosion and tightened enough on the posts. Also, you're positive you connected the starter up properly? Just gotta ask dummy questions as you never know.
Old 03-10-2011, 06:17 PM
SC Durango owner
yes I have, thank you though. I am thinking that it may be an ignition problem but, tired of putting money in the thing on stuff that isn't wrong with it....you know
Old 03-10-2011, 07:37 PM
stratuser's Avatar
stratuser
stratuser is offline
I would check your a/c compressor and make sure it isnt locked up. Mine was doing the the same thing clicking as if it was a ignition problem.
Old 03-10-2011, 07:47 PM
SC Durango owner
I have put a new compressor, condenser, whole new air conditioning system, lines and all, radiator, fan, battery, alternator, starter...you name it lol all but a new motor...any other suggestions?
Old 03-10-2011, 09:12 PM
stratuser's Avatar
stratuser
Did you check the starter solenoid?
Old 03-10-2011, 09:31 PM
jmess's Avatar
jmess
jmess is offline
neutral safety switch?
Old 03-11-2011, 07:08 AM
Mean Green's Avatar
Mean Green
Mean Green is offline
Take a look at a wiring diagram for the starting system and follow the power and control circuits for the starter. If you have a voltage drop across anything other than the starter on the power side or the starter solenoid on the control circuit you have just found your problem. Read the electric testing sticky to get a grasp of what to do and don't throw more parts at until you have verified a bad part. It would have been cheaper at this point to take it to a shop.
Old 03-11-2011, 12:26 PM
hydrashocker's Avatar
hydrashocker
hydrashocker is offline
Clean the battery terminals and battery posts, if you still have the problem swap the starter relay in the PDC. If you still have the problem replace the starter.
Quick Reply: Starting problem...HELP???
