Signal Light Problem
I have an 2003 durango, when the headlights are turned on the right indicator light stays solid and after a few minutes the truck starts to chime and will not stop.
Any ideas? |
Whens the last time you checked your battery?
does the indicator in the dash go solid too? if so i would say you have a crossed wire somewhere which is applying voltage to that circuit, time to start following wires and looking for the bad insulation/short/loose plug ect ect.
