Durango Starting Problem(s)...
Hey guys I did a bit of searching and couldn't find an answer to my problem so I figured I would ask you guys.
AS I have stated before I have a 1999 Dodge Durango SLT 4x4 with a 5.9 V8 Magnum. About a week ago, I had a problem where it refused to start. It would turn over, but not start. I had it towed to my local shop and it turned out to be the ignition coil. After that if worked just fine. However today I came out after working out at the gym and it turned over however didn't start, but after releasing the key, I could still hear the starter spinning for a few seconds. After about 2-3 minutes I raised the hood and tugged on the battery cables in a bit of frustation, then the Durango started like nothing happened and drove home just fine...
Any idea what might be the problem???
Thanks in Advance,
Brekar...
Thanks in Advance,
Brekar...
Trending Topics
