need help wit my 2000 dodge durango
Can someone plz help me and tell me whats wrong with my truck? It will turn over but wont actually fire up or start. I replace the batter and battery cables last nite, it had tuneup bout 2 monts ago with new air filter , new oil filter.. ..... i can get it turn over but it wont actually start i need some suggestion as to what else culd b wrong, i have someone that can fix it
there's a notch out of the bell housing of the transmission where it goes. It is on the passenger side towards the top of the bell housing. I can't remember for sure if you can get to it from the engine bay or if you have to take out the passenger side fender liner to get to it easily. As for testing it I have no idea how you would go about doing that. The first thing i'd do is trace the wire and make sure the connection is good
another thing you might want to check is that you have spark on all cylinders as well.
ok sorry it is a 5.9 in it. if that helps. im just so frustrating cus i toke it out saturday ran fine, then when i went to start it for work it wuldnt start, thought mybe bad connection on battery cus my posts were pretty corroded, so that why i put new battery in it along with new terminals and battery cabels then it still wuldnt fire up for me...
check the coil, pull the wire going from the coil to the distributor, put a spark plug in it, and hold it to the block, see if you get spark, if not check the connections at the coil for power, if there is power, clean the connections and re-check for spark, if there is still no spark replace the coil.
Trending Topics
i drove my durango last night to a friends .was there 4 two hrs went to crank it and all it would do was turn over but not fire what could be the problem
i drove my durango last night to a friends .was there 4 two hrs went to crank it and all it would do was turn over but not fire what could be the problem.please somebody give me answers
:icon_naugh ty:i drove my durango last night to a friends .was there 4 two hrs went to crank it and all it would do was turn over but not fire what could be the problem.please somebody give me answers
Last edited by shrpshtr325; 08-07-2012 at 05:57 PM. Reason: triple post is unnecessary and against the rules
