DodgeForum.com
DodgeForum.com (https://dodgeforum.com/forum/)
-   1st Gen Durango (https://dodgeforum.com/forum/1st-gen-durango-69/)
-   -   Engine won't even crank (https://dodgeforum.com/forum/1st-gen-durango/315467-engine-wont-even-crank.html)
shloho Jan 15, 2012 10:40 PM
Dodge Durango 2000 won't start from one minute to the next.
Engine won't crank. I turn the key and nothing happens. No lights etc. a few times, when inserted key, ipod began to charge and the overhead lights came on for minute or so, but very dim and then wouldn't go back on after took key out and tried agina to crank the engine. What's going on?
that_guy Jan 15, 2012 11:01 PM
check your battery and your battery connections. make sure they're tight and clean, and you may want to have your battery load tested.
shloho Jan 15, 2012 11:07 PM
I had a new battery installed about 6 months ago. About two months later I had the battery connections cleaned, and I replaced the terminal connections (not sure if I got the terminology correct).
that_guy Jan 15, 2012 11:10 PM
still, make sure the connections are tight and clean. things can change in 4 months, the terminals could have worked themselves loose and/or corrosion could have built up
hydrashocker Jan 15, 2012 11:45 PM
It could be the other end of the cables like on the starter.....ect.
It is giving you a classic bad connection or battery signal.
shloho Jan 16, 2012 12:10 AM
Will check it out in the morning. I really appreciate the help. Thanks
shloho Jan 16, 2012 12:12 AM
Gonna check it out. Will let you know how it turns out. Thanks
otgarzā Jan 16, 2012 03:11 PM
It can be a few things but most commonly its loose connections or corrosion on of the ends of the connections. Check for tightness and corrosion on the connections leading to the battery, starter, and alternator. If it continues then we can help you step by step on here
shloho Jan 16, 2012 10:50 PM
It was the connection at the battery terminals. Thanks guys!
otgarzā Jan 16, 2012 11:12 PM
No problem glad you got it resolved. Damn connections are so discouraging lol.
© 2026 MH Sub I, LLC dba Internet Brands
