What is the operating temp?
It's done on the O2 sensors. See they have heaters in them that is why they have 4 wires each.
That is where my Durango ran for the most part.
You get more power and less ware at 180 then you get at 195 which is OEM. The only reason they went to 195 was because or emissions and comfort, not for running better. This is why a 180 is good for towing. It keeps the heat down which intern creates a better HP and torque, thus more power!
Ya know my Durango always ran cold, but I didn't care because it helped keep my motor in better shape. What is a problem is the fact you are getting hot. I would replace it and also replace the T-stat housing. You can get it at the dealer for cheap. A 180 is the best for that motor anyway.
Your Durango factory operating temperature is 195 degrees. For the modders, we like to have our trucks run a little cooler to prevent heads from cracking after many years of use at 180 degrees. If you modify your temp to run less than 180, you might not pass inspection and your PCM may throw a P1281 code that says taking too long to warm up to operating temperature.
The factory has designed a fail safe limit on the PCM to put your engine in limp mode when temperature approaches 210 degrees to prevent you from blowing the engine. You will experience crappy mileage and loss of power.
Normally by the time you creep up to 210, the electric cooling fan would be switched on to assist the clutch fan.
After my truck was holding at 210F, I can definitely tell, no power at all. Felt like I was pulling a trailer. My MPG fell down to 8-9 mpg. After replacing the faulty fan clutch, this issue never came back as my truck never reached the 210F mark.
