Code 0740
Im having the same exact problem. I have a '99 durango 4x4 5.9l and i keep getting the p0740 code. I changed the fluid and filter and the fluid level is correct but i dont have any problems. my rpms are correct and there isnt any problem with the lockup. Maybe i should just replace the tcc/od solenoids just to see if it knocks out the code? Help! I have driven with the code for 2 months and nothing is out of the ordinary. I cleared it and it took about 2 weeks for it to show up again..?
on
Here is a TSB, Try this and post.
EFFECTIVE DATE: Oct. 02, 2000
SUBJECT:
46RE Transmission MIL Due To DTC P1740 – TCC or OD Solenoid Performance
OVERVIEW:
This bulletin involves the replacement of the transmission pressure boost valve cover
plate.
MODELS:
2000 - 2001 (AB) Ram Van
2000 - 2001 (AN) Dakota
2000 - 2001 (BR/BE) Ram Truck
2000 - 2001 (DN) Durango
NOTE: THIS BULLETIN APPLIES TO VEHICLES EQUIPPED WITH A 46RE
TRANSMISSION BUILT BEFORE AUGUST 01, 2000 (MDH 0801XX).
SYMPTOM/CONDITION:
The customer may complain of a Malfunction Indicator Lamp (MIL) illumination. Upon
further analysis, it is determined that the MIL is caused by Diagnostic Trouble Code (DTC)
P1740 - Torque Converter Clutch (TCC) or Overdrive Solenoid Performance. Other than
the MIL, the customer may not notice any other condition with the transmission.
This condition may be caused by an intermittent and momentary TCC disengagement
condition. The transmission valve body pressure boost valve cover plate has been revised
with a larger size orifice hole to address this condition.
DIAGNOSIS:
1. Warm the transmission to normal operating temperatures.
2. Using the DRB IIIŅ, perform a torque converter clutch (TCC) stall test. The stall test
has been revised so that the TCC remains engaged for a period of four (4) seconds.
NOTE: THE DRB III MUST BE OPERATING AT RELEASE LEVEL 50.4 MDS2
SYSTEM CIS CD2067 OR HIGHER (AVAILABLE THE WEEK OF OCTOBER 2,
2000) IN ORDER TO PERFORM THE REVISED TORQUE CONVERTER
CLUTCH STALL TEST. DO NOT USE EARLIER VERSION STALL TEST TO
DETERMINE CONDITION OF THE TORQUE CONVERTER CLUTCH.
3. If the engine stalls as a result of the TCC stall test, then perform the Repair
Procedure.
4. If the engine does not stall, as a result of the TCC stall test, then further diagnosis is
required. The technician may want to consider the following components during
their additional diagnosis: a cut or worn input shaft seals, a missing pump lock-up
circuit check ball, or worn converter hub, input shaft, reaction shaft, and pump rotor.
PARTS REQUIRED:
1 04617015 Plate, Pressure Boost Valve Cover (46RE)
1 02464324AB Gasket, Trans Pan
10(AR) 05010124AA ATF+3, Transmission Oil Type 7176 (2000 M.Y.)
10(AR) 05013457AA ATF+4, Transmission Oil Type 9602 (2001 M.Y.)
REPAIR PROCEDURE:
1. Clean the pressure boost valve cover plate to remove any dirt or rust inhibitor prior to
installation. The revised cover plate will have a 1.75 mm (0.069 inch) orifice hole
versus a 1.22mm (0.048 inch) orifice hole in the original plate. Make sure it is clean.
2. Using the appropriate Service Manual, Group 21 – Transmissions and Transfer Case,
replace the transmission pressure boost valve cover plate p/n 04617012.
3. Verify fluid level after warming up the transmission and cycling the shift lever several
times.
4. Verify, and if required, adjust the transmission shift linkage and the transmission
throttle valve cable per the appropriate Service Manual procedures.
SUBJECT:
OVERVIEW:
plate.
MODELS:
SYMPTOM/CONDITION:
DIAGNOSIS:
Procedure.
PARTS REQUIRED:
REPAIR PROCEDURE:
times.
