2002 Durango Compressor-can't get the sum bitch out
I've removed all bolts, nuts etc, and there is a rear connection on the right that seems locked in. Any ideas on getting this thing out?
Thanks, John d |
bump....any help?
Did you remove the bracket that the lines are held to?
Assuming we are talking about the 4.7L, when I changed mine, I had to use a really long flathead screwdriver to act as a small pry bar to pull it out. As long as the 3 mounting bolts, the 1 bolt for the lines, and all connections are removed up top, there is nothing holding it down below that I can recall. Just a tight fit
Originally Posted by RockGuardedDak
(Post 3025204)
Thanks for the replies. I kind of figured it was just a very tight fit, did not want to break anything though. John |
| All times are GMT -4. The time now is 08:21 PM. |
© 2026 MH Sub I, LLC dba Internet Brands
