Transmission leaking
I have a 2000 dodge durango slt 4wd 5.9l the transmission is leaking from the inspection pan and have no idea where its coming from can anyone give me any ideas what i could be.
It's probably from the torque converter seal then
Originally Posted by chadparadis
(Post 3182933)
Verify its transmission fluid. When my rear main seal started to leak it came down the inspection plate and dripped off the transmission. Either way your going to be pulling a transmission or just about pulling a motor to replace a seal. |
i have verified that it is transmission fluid about a half qt a day. transmission doesnt feel like its slipping and the tranny has about 125k on it
Just a suggestion, have you checked to see if all the pan bolts are tight?
