Pspklutch |
08-30-2016 08:59 AM |
As in? Not sure I understand. Did you take them out and now trying to figure out what orientation to put them back in? If so, you can put them in on the keyed side, then push them up into the frame until they stop. The put the arms on the end of them. The arms should be point down and out away from the truck. Probably around the 150° range. Enough to get the lower control arm bolts in but that's about it. Don't go too high up, you'll be tearing the entire front end apart again to fix it
