1998 Durango - Fuel Pump fuse or fuel pump?
Pulled ito parking space running but now won't run except for short bursts. Runs if I put gas into throttle body for a few seconds. I swapped the fuel pump relay and same thing. Is there a fuel pump fuse? Where is the ASD relay located? BTW - I don't hear any initial noise from the tank when the key is turned on.
ASD relay and fuse are in the box under the hood.
