over heating issue after replacing radiator
Old 05-02-2019, 09:49 AM
Erickthebold's Avatar
Erickthebold
Erickthebold is offline
Default over heating issue after replacing radiator
I have a 2000 Durango with the 5.9 engine.
Radiator got hole in it so replaced it. also did the water pump, cap and thermostat at same time.
Now am seeing that the overflow bottle gets water to it but it doesn't go back into the system. I now see hot water coming out at cap as water pressure and heat get to normal. thus resulting in over heating.
Have tried all the tricks to ensure that there is no air in the system. Have checked system with pressure tester and loos no water.
Any ideas, as now can drive it about 10 miles and then have to add water?.
Old 05-02-2019, 10:49 AM
HeyYou is online now
Dodge Forum Administrator
Received 3,177 Likes on 2,930 Posts
Water won't go back into the system until the engine cools. As it cools, the coolant contracts, creating a vacuum in the radiator, which will suck the coolant back in. Do you have the wrong radiator cap??
Old 05-02-2019, 11:14 AM
Dodgevity's Avatar
Dodgevity
Dodgevity is online now
Sure you didn't install that thermostat backwards?
Old 05-02-2019, 01:20 PM
Erickthebold
Have tried the new one and the old one same results. Can't understand why it starts blowing water out at the radiator cap.
Old 05-02-2019, 01:21 PM
Erickthebold
Pretty sure, if in backwards it shouldn't circulate the water, right? and it does do that.
Old 05-02-2019, 02:02 PM
ZEN357's Avatar
ZEN357
ZEN357 is offline
Did you flush the block and heater core when you replaced everything?
Old 05-02-2019, 04:31 PM
Dodgevity's Avatar
Dodgevity
It would circulate the coolant already in the block, like cold start. It would never open up to circulate the radiator contents. How do the top and bottom hoses feel when it starts to overheat?
Old 05-02-2019, 06:20 PM
If you are running it with the cap off, yeah, when the 'stat opens, it's gonna blow coolant out. Especially if there is still an air pocket in there...... Need one of the neat funnels designed for just such an occasion.
Old 05-02-2019, 11:12 PM
car5car's Avatar
car5car
car5car is offline
Every new thermostat has to be checked in boiling water with old one.
Old 06-10-2019, 08:33 PM
tshephard's Avatar
tshephard
tshephard is offline
I had all kinds of water and heater problems until I fixed the head cracks.
All that stuff works way different now, with all the same old parts....
I suspect the cracks were such that combustion got pushed into the water but water did not leak to pistons sitting.
5 out of 8 cylinders, intake to exhaust, $600 Jegs heads
Quick Reply: over heating issue after replacing radiator
