Climate control fan, only works on high.
Old 05-26-2006, 02:50 PM
KD's Avatar
KD
KD is offline
Default Climate control fan, only works on high.
Hi all, first post on this form, so far great reading thanks!
The wife's 03 Durango had the front climate control fan crap out, it only works on high. I assume that there is a module with resistors for the lower speeds. Can anyone point me in the right direction? I don't have a manual yet (warrenty just ran out so time to buy one). Thanks in advance for any help.
Kelly
2004.5 CTD RAM
2003 Durango
Old 05-27-2006, 04:22 AM
yakkier's Avatar
yakkier
yakkier is offline
Default RE: Climate control fan, only works on high.
Prolly just the switch, See dodge went the hightech way on it's switches, thats why they cost so damn much, Ok your fan switch actually has a copper plate with tons of lil holes in it,with lil springloaded ball bearings that will spring into these different holes, each row of holes send a higher current flow that is sent to the blower, which changes the speed of the fan. Well if the copper plate is dirty or if any of those ***** become stuck, loose or are completely knocked loose.. it will cause it to mess up.
Old 05-30-2006, 12:28 PM
KD's Avatar
KD
KD is offline
Thanks, I'm going to tear it apart this weekend. I'll report back what I hear.
Old 05-30-2006, 08:46 PM
yakkier's Avatar
yakkier
yakkier is offline
DONT TAKE IT APPART!!!! you have to replace it, theres no fixing it cause every thing in that is put tgeather with a machine, if you take it appart theres no way you'll get it back togeather.. trust me i made the same mistake lol
Old 06-27-2006, 08:52 PM
KD's Avatar
KD
KD is offline
Finally got the manual, few tests with the DMM and isolated it to the blower moter resistor block. Wow couldn't believe the stealer wanted under $20 for the modual. Pluged it and and we're back in action.
By the way they have a new part, they must have realized the old design was crap.
Old 06-27-2006, 09:48 PM
yakkier's Avatar
yakkier
yakkier is offline
Good i'm glad you got it fixed bro!
Old 07-07-2006, 02:32 PM
Air757's Avatar
Air757
Air757 is offline
Hey i have the same problem on my 2003 Durango ,, Please help,, where is the location of the ristor block, thanks
Old 07-07-2006, 04:30 PM
Kensai's Avatar
Kensai
Kensai is offline
Passenger side, near the center console. You will see a wiring harness bolted down by 2 screws problaby either 7mm or 8mm in size.
Old 07-10-2006, 12:38 PM
KD's Avatar
KD
KD is offline
If you were laying on your back on the passenger side floor matt, with your head under the dash. Right in front of your face is the blower motor, 6-8" towards the center of the truck is a wire bundle plugged into what looks like an air duct. This is plugged into the resistor block. Two 8mm screws/bolts and it comes out.
Old 01-03-2009, 12:55 AM
AudioPsycho's Avatar
AudioPsycho
AudioPsycho is offline
just found this i want to say also if you ever have to pull your dash off to install a new headunit and this problem happes there is a little plug in the same place you guys are talking aobut that can come unpluged yalls info made me look down there and saw it want to say thank you
Quick Reply: Climate control fan, only works on high.
