rear windsheild res
how do i access the rear washer tank...hoses fell off and cannot reconnect....any help would be great
RE: rear windsheild res
I'm guessing this is a newer Durango? You have to let us know what kind of D you have or we will not know what to tell you. If it is the 98 to 03 model then you only have the front windshield washer fluid tank with a pump for the front and a pump for the back...
ORIGINAL: Mean Green If it is the 98 to 03 model then you only have the front windshield washer fluid tank with a pump for the front and a pump for the back... |
Really? That's news to me. :D Mine pulls straight from the front reservoir.
That is the location of mine. Under rear hatch, right side, 2/3 the way up.
I guess in some ways it's better god forbid mine ever get a busted line that would be a PITA to fix I would propably just plug up that part of the reservoir. Also a lot less line to freeze up in the winter. I used the stuff that was supposed to be good up to -30 degrees and it still froze in the lines. [:@]
How cold does it get up there?
At the coldest-5, -20 with the wind chill. but for some reason my lines froze up consistently in the rear. Thank God nothing cracked.
2005 Hemi Durango is front ONLY no rear....
