cleaned up my DD
cleaned up my DD
Righto well i cleaned up my daily driver and shes all shiny (may not be the best but at least its not spray paint like my other) Im thinking about switching all my "goodies" over to the DD exept the cam, and the shift kit.
BUT before i do that i have to get the codes 37, 21, and 11 taken care of.
11 "Intermittent loss of either camshaft or crankshaft position sensor,/No crank reference signal detected during engine cranking/Timing belt skipped 1 tooth or more from initial learned value," Definatly not the timing. So im hoping its the cam sensor, (because its easy to change)
21 "o2 Sensor" I can live with that, my rice car has a bad one.
37 "Torque converter clutch solenoid circuit or park/neutral switch failure" WHAT? im lost. (it is an auto)
Well Heres tina (i named her tina) I think im gunna swap over my duals, My projectors, UDP and rims.... but im indecisive so i dunno yet
I put some eyelids on her to spice thigns up a lil =D
RE: cleaned up my DD
Your Park/Neutral Switch ATX may be bad. Check the wiring and make sure its clean and plugged in.
Trending Topics
yea I can also let it warm up without the cap on and let the bubbles come out (if thats the case) thats what we did on my other.
Now about the gray bumpers. If i rattle can them (decently) will it look ok? Ive never seen anyone with canned bumpers. (besides myself But mine were dull plastic and not gloss) Or i could get a front kit (like an R34) and then get a stock black back bumper. Im still "i dunno" about the whole thing yet =D
OHHH yea The front end Bounces... not wiggle. But bounces. its not wheel hop because im moving at like 50 or whatever it wants to be doing. The steeringwheel doesnt wiggleeither way. So im confused as to what it could be? Ive never had a bounce.
