problem
problem
well I figured out the burning smell.It was coming from the driver side rear brake.After for driving for about 30 min,I could feel the intense heat coming from it,and the smell.I put a straw to it and it would melt it lol.Anyways last night driving home something weird was happening.The car started to buck,I was in 5th gear going about 40.It felt like the engine was gonna die.I downshifted into 4th and then it got worse.The check engine light then went on so I pulled over and shut it off.I started it back up and about 2 minutes later it started to do it again,again I shut it off while the car was driving and the problem went away.I found this weird,anyone have any ideas?I dont really know anything about cars,but the only thing I could think of was like a misfire?something to do with the spark plugs.
RE: problem
well everytime you turn off the ignition the check engine light goes back off.It doesent go on when I start the car up again.bad thing though I just tried to drive and everytime I hit the gas the engine bogs down and is ready to die.Then when I actually try to move the car just completely stalls,and I cant move.
RE: problem
ORIGINAL: Brandon_G
https://dodgeforum.com/m_63384/tm.htm
