cv joint or clutch
RE: cv joint or clutch
will the transfuild really make it slip becuz everyones told me put it in fouth and jam the gas if its slips its the clutch but it does it in third 2 and ive been told u shouldnt but im really really hoping its the cv joint becuase the clutch seems like it did the day i bought nice and stiff
Just because the pedal feels tight doesn't mean the clutch is put in right. The real question is how long after you put the clutch indid it start doing this. If it has just started this and the clutch was changed 7 months ago. Then I would replace the cv joint since it is really really bad (to me it sounds like it is stripped on the splines of the axe where the joints are on the axels). How much have you been hot ******* it. That will wear a clutch out quick.
ill dog it once every week but its not that bad only speed ^ 2 4-5k and shift really quick until i reach da speed limt but its only once mayb every weekmay it have to do with he clutch pedal cable getting hung ^ somewhere becuz there is bout 1.5 inches of play in my clutch pedal but its been like that since i got the car and afta the clutch was fixed
The first thing i would check on the clutch play is the ½" pin that it piviots on. Look make sure the bracket itself doesn't move.Check the top where the cable is attached see how much play there is between the cable and pedal. And if these problems are not what is causing the 1½ play. You may want to start checking the throw out bearing
But back to the axel it neds to be replaced before it leaves you on the side of the road
Trending Topics
