Mopar better the Tb Spacer + DOHC Pcm
RE: Mopar better the Tb Spacer + DOHC Pcm
you get what you pay for.i do think that a swap over to the dohc would have some affect but not as much imo you would still need to go back to stock if you ever wen't turbo so i say go with the dohc for now and see what happens and of course make a post about
Trending Topics
got to love modern i don't evencare if howell was giving stuff away i would not want to wait a year i know that modern ships very fast if modern has itthats where im going to get it....if anyone from modern reads this i want a free hoodor hanh kit
The Gtech said the combo of TB Spacer and DOHC pcm from an automatic gave 11hp between the 2. It was an upgrade and I havnt lost power,so pretty much it feels good and the Gtech resultswere affectedso I know they are working : )
Theres also a chassis dyno in townI tested and the results were the same within 1-2hp off from the Gtech. But I will eventually upgrade to the Mopar PCM for adjustability and speed limiter removal. The DOHC pcm is a quick go fast trick if you have parts laying around or know of a junk car with one that you can get for under $50.
