wire harness HELPPP!!!
RE: wire harness HELPPP!!!
Not much, it depends on what year DOHC you get. If it is from the same year, you may just have to splice the CTS, possibly the cam sensor. If it is from a different year, you may have to splice the MAP sensor, TPS, fuel injectors, alternator wires, the brown wire going to the starter, IAT, etc. Unless of course you use the SOHC injectors, and TB, then you would have very little splicing to do...
