So my neon seems to be lacking when it comes to power. Not only that it will hesitate. I will give it enough gas to slowly let off the clutch but then it seems like the gas stops flowing for a sec as it boggs down. I looked at the plugs and they all have a chalky white look. I feel like it has to do with the fuel pressure. i don't have a gauge of any kind though. if it is the preasure, would this be fixed with a new regulator, fuel accumulator, or sending unit ? Thanks for any help.
a good way to know if its running lean is it will heat up quick and/or overheat and check your fuel pump make sure its constantly workin not a bad wire or something you can pick up a cheap hand held fuel pressure gauge at autozone etc.
i called and asked, and they said they just have a $150 one that you can buy, then return. But thats it, and I don't got that right now. Any clue where I can get one?
did you try other auto part stores when you pay the 150 you get it back its like a deposit but if you dont have it you dont have it i understand i dont know where else you could go
