transmission re-installed
I have a 1996 neon automatic i just replaced the front transmission seal and re-installed the transmission everything lined up the bolts for the torque converter and the block bolts all lined back up and i went to start it after putting it all back together and the car wouldnt start battery good,grounds good,starter good found out the flywheel wont budge anyone have any ideas someone told me the torque converter wasnt lined up right but if that was the case i dont think everything would lined up fine and i know its not the motor its brand new has a brand new waterpump and timing belt and lots of headwork done and it was running before nice and smooth just the trans seal leaked like a sive so had to pull everything out all over again any ideas cuz im stuck
