95 neon nyg sport...issues
1 Attachment(s)
I got this neon to make it my daily for a while. When I got it it was taken apart quite a bit. While I've had several neons before never a 95. I noticed a lot of the brackets and vacuum lines are different. I've since replaced the clutch, flywheel, various gaskets, rear main seal, brake lines, water pump inlet tube, shifter cables, and probably something else I'm forgetting...but I'm left with one clip/bracket that I have no clue where it goes. Any help would be great. Thanks. If it helps its a sohc 5speed
