DodgeForum.com
DodgeForum.com (https://dodgeforum.com/forum/)
-   1st Gen Neon (https://dodgeforum.com/forum/1st-gen-neon-77/)
-   -   mitsubishi eclpse won't crank (https://dodgeforum.com/forum/1st-gen-neon/64649-mitsubishi-eclpse-wont-crank.html)
gthutch Jul 6, 2006 08:07 PM
If anyone can help me it will be greatly appreciated, i have a 1995 eclipse 2.0 dohc non turbo, i bought this car and it had been sitting about a year, it cranked up and run for about 3 or 4 minutes running it about 3 to 4 thousand rpms then it shut down and will not even try to crank at all. here is the low down it is firing on all spark plugs i replaced fuel pump it is getting gas but will not even act like it wants to crank , is the ecm bad crank senor bad cam sensor bad i need help please thanks.
das2123 Jul 6, 2006 08:11 PM
RE: mitsubishi eclpse won't crank
You do realize this is a neon forum correct?
Anyway, if it sat for a year did you drop the gas tank, clean it out and put it fresh gas?
You might find more help here...
http://www.dsmtuners.com/forums/
gthutch Jul 6, 2006 08:14 PM
yes i did and was told it was same motor as neon
das2123 Jul 6, 2006 08:18 PM
ORIGINAL: gthutch
You were told wrong then. They have the same block, but that's it. The heads are different as well as internals.
© 2026 MH Sub I, LLC dba Internet Brands
