Cleaning TB.......
Cleaning TB.......
I just got a ATX TB from the JY today. The poor Neon was sitting with it's hood off, intake off, and the TB filled with water. I got it pretty clean but I was just wondering what to use to clean the wall of the TB on the inside. It's a little rough and I want to polish it up for the best airflow. I have a dremel but I didn't know if I should use the wire brush or aluminum or not. Thanks a lot.
RE: Cleaning TB.......
oh wait, do you mean rough as in dirty?
Either way, I cleaned the whole throttle body on my neon with carb cleaner + old toothbrush + q-tips. I used the toothbrush to do the sides to get the black **** off. But if you want it smoother (un-rough) wet sanding 1000grit is the way to go. 2000 would be better but would take more time... probably twice as long?
Trending Topics
