Pics of your lifted d150 2wd!!!
New to the forum and definitely a new dodge guy. Just picked up a 91 D150 2WD as a side project. Wanted to do heavy duty springs with coil spacers and a body lift to hopefully make me able to clear some 35’s on her. If any of you guys on here have a lifted D150, let me see some pics and please give me some advise on where to start! Thanks!
-Mike
sucks that it is a long bed. the short beds look a bit more badass when lifted. i almost want to get another short bed or 2wd ramcharger frame and stick a truck cab on it. i forget what size tires Richard(Sixgun) is running but i think thy might only be 33 which pretty much max out the suspension
he does have lift springs but no coil spacers. i don't know if the coils he used were a on the shelf part. i think he might have called someone to custom order a set. i know he has a add a leaf in the back but i think he might have lift blocks on top of that. he also 3" body lift. it pretty much requires all that to run the 33" tires.
Trending Topics
if you search 91 RAMM'd 150 you should find the thread he started about his truck. he has some info and pictures of it after the suspension lift on page 21. defifnitely need the body lift on top of the suspension lift to run 33's. i don't know if you will be able to run 35's like you want or not but i guess you will see.
