changing gear ratio
Old 06-21-2008, 01:42 AM
Mike001's Avatar
Mike001
Mike001 is offline
Default changing gear ratio
Now that my engine work is all done (hopefully) time to do something about this horrible 2.76 rear end. What parts am I going to need to bring to the shop? Just the ring & pinion set and an install kit?
This is what I'm looking at
Chrysler 8.25" 3.73 Ring and Pinion $232.89
1976+ Chrysler 8.25" Overhaul kit $73.61
$250 for labor
I'm actually teetering between the 3.55 and the 3.73 gears. This truck's main job is to haul about 4500lbs of boat around the state so I need a compromise between power and rpms on hilly back roads and interstate highways. I'm leaning towards the 3.73 though.
Old 06-22-2008, 02:24 PM
nemesis_SS's Avatar
nemesis_SS
nemesis_SS is offline
Default RE: changing gear ratio
they made this truck with a factory 2.76? why?
Old 06-22-2008, 02:26 PM
nemesis_SS's Avatar
nemesis_SS
thats the 8 3/4 one found on many mopar cars right?
Old 06-22-2008, 02:29 PM
Comma's Avatar
Comma
Comma is offline
Where do you live? I need a 2.76 rear, my 3.55 is on the way out. I'd reccomend a 3.73 purely because you say you are in hilly terrain.
Old 06-22-2008, 02:33 PM
nemesis_SS's Avatar
nemesis_SS
if he lives too far and that 2.76 is still pretty id like to be second in line
Old 06-22-2008, 03:40 PM
Mike001's Avatar
Mike001
Mike001 is offline
Pretty sure Ive got an 8.25 not the 8.75.
Casting #3723599
I'm guessing it's the 2.76. I cant read the tags and the drive shaft fell well short of 3 turns when I spun a tire twice.
I'm in mid Missouri. The truck only has 25K miles on it so the rear should be in great shape but I'm only looking to swap the gears, not the whole thing if I dont have to.
Old 06-22-2008, 04:27 PM
moparborn's Avatar
moparborn
moparborn is offline
You most likely have the 8.25.
The 8.75 uses a third member,the 8.25 has the cover plate.
its not a 9.25?
Old 06-22-2008, 04:49 PM
Mike001's Avatar
Mike001
Mike001 is offline
here's a pic
[IMG]local://upfiles/72844/5B500BAFEF80442999695BFEC7884360.jpg[/IMG]
Old 06-25-2008, 12:46 AM
Mike001's Avatar
Mike001
Mike001 is offline
Anyone know if an 8.25" axle from a late jeep cherokee will fit my truck? The local junkyard has a bunch of 3.55s.
Old 07-07-2008, 04:51 PM
turbododgepirate's Avatar
turbododgepirate
turbododgepirate is offline
Thats a good old 8.25 in the pic there.
I'm keeping mine and adding 3.90 or 4.10 gears and a posi unit to tow.
Quick Reply: changing gear ratio
