transmission problem
Hi.
My W250 was sitting a few weeks and the passenger side rear brake somehow was stuck on which I did not know. I thought maybe the tires were stuck to the frozen to the ground. I tried to rock the truck. Now the truck will only go in reverse. Foward motion was very slow with excessive trans slipping. Will now not move forward at all now. Is there any adjustment I could try short of replacing the trans?
i was actualy refering to the fluid level not the condition of the fluid but the fluid not being burnt is good. you need to check the fluid level with your truck running while in neutral. the fluid level rises when you turn your truck off so it may apear like there is enough fluid but there is not.
I know this is going to sound really stupid but I will bet your rear clutch has let go. The rear clutch is not used in reverse but instead is used in all forward gears. Go to this site and scroll down to the section labeled "The torqueflite in operation" and read the section on reverse operation.
http://www.allpar.com/mopar/transmis...-tom-hand.html
Trending Topics
