1993 Dodge D-150 5.9 MFI (Best way to tune up and gain power a little help?)
Unfortunately there is very little you can do in that department without spending massive amounts of money and changing everything. The computer controls everything and these early ones are set and can not be tweaked. Depending upon where you live you might be able to do some exhaust work to help it breathe.
replacing the plenum plate and gasket might free up some power that is lost when plenum gasket blows. if you replace the plenum plate and gasket it then may be a good idea to then replace the cat and O2 sensor. from what i have read the magnum engine seem to like ngk o2 sensors
https://dodgeforum.com/forum/2nd-gen...um-thread.html
Yeah I've researched depending on the profile of the lobes I can cam it without flashing the computer and while in the block I'd do valve springs and lifters these magnum engines have rocker shafts right? Where the arms are on a whole shaft bolted to the head and plus I can't decide is flowmaster 40 series or the delta 40's would be better and I was thinkin 3.73's in the rear is that too big?
Trending Topics
